D/W fill with water and then hums
Hi, My d/w fills with water, and then you just hear a soft humming sound. I open the door and the water is hot but that is all the d/w does is fill with water. won’t run, won’t drain just fills with water. It is used a lot, so I don’t think the motor is froze. What else do I check?
