D Calhoun
During wash cycle, washer fills and continues to fill till water is running out the door. Not Good. :mad: I then turn off water supply and press the drain button. Washer drains. If I turn the water supply back on, water enters the washer with the door open. Any suggestions? :confused: All help appreciated. Thanks :rolleyes:
Replacement parts for WHIRLPOOL DU920PFGB1 DISHWASHER | AppliancePartsPros.com
Sounds like your water valve (Item 16 in Section 3) is sticking open.
There are a couple reasons I believe this:
  1. There should be no power to it when the door is open
  2. The over fill switch should kill power to it when it overfills.
So if we assume it is open with no power to it, it is toast.
