While moving a Frigidaire, the doors were removed and the water dispenser line was cut at the door of the freezer. How do I repair or replace the line?
It’s hard to say without seeing the damage. If you can post a pictures it might help better.
There is usually a junction of the line there where it can be disconnected for that purpose. If you have enough sticking out you may can replace it with another union. http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfMjAxMjUzMDQyL0lDVy9zb3RvaHB0cmFwLw%3D%3D
