Our dryer has an E68 error code and beeps continually… however when it is running it flashed lights on the panel but seems to be working normally… any help in figuring out what or how to find this error and fix it.
Check your tech sheet inside the unit should be uptop under top lid or at the bottom of the unit…Crosley is made by whirlpool…I’ve noticed e68 codes if i’m not mistaken are a main board or touchpad issue in most cases…good luck
