Crosley Dryer--will only turn on in "cool down" on auto setting
I first thought I had a blown fuse problem, but that wouldn’t explain why it will still turn on when set to cool down, under the auto dry section. Now I’m thinking maybe it’s the timer. If so, could this be an easy at-home fix or should I put a call out?
Can anyone shed light on this?
Thank you!
Hi.
Most likely it’s the timer.To replace it you need to open the control panel and take out two screws.
The timer AP6009056
Here are the breakdown diagrams and Replacement parts for Whirlpool CEDS563SQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
