Crazy flashing lights! Whirllpool Quite Partner 4
The dishwasher has a mind of it’s own! Help Random flashing lights,once if finally picks a cycle I can run it and it seems to run fine. I can no longer oick my own cycle and sometimes I can’t even get the lights to turn off. I talked to a local repair tech and he seems to think the wires have come lose in the circut board. Can this be easly fixed? can My husband do this?
Any idea how to find the circut board?
Thanks,
Jenn
Hello jenjen7471,
Disconnect the power coming to the dishwasher. Remove the inner door panel and acceess the control cover. Remove the control cover, and clean the ribbon cable connection. Make sure there is no moisture on it. Reinstall and see how it performs. If you are still having problems, you may have a bad control panel assembly. Hope this helps. AP6014738
