Control touchpads do not respond
The control touchpads do not respond when pressed. When I press the start button on the front, the dishwasher starts on the last cycle that I selected before the controls stopped working and the indicator light next to that setting lights up. HELP!
Replacement parts for MAYTAG MDB8751BWS | AppliancePartsPros.com
Here is an operators manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%206920186.pdf
And here is a tech sheet
https://www.servicematters.com/docs/wiring/Schematic%20-%20W10128608.pdf
First try to unlock the keypad Page 10 of Operators Manual
Next try removing power from the units for half an hour or so to see if it will reset.
Next try to run the diagnostics on the tech sheet
Next RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
Next check the keypad switches with a meter, see the tech sheet
Also check the wires going from the control to under the unit.
There has been a lot of problems with rinse aid leaking and causing all sorts of problems.
