Control panel
Third time in five years, the control panel has gone out.
Any problems on grounding, etc. Is there a recall on this dishwasher:confused:
Here is a recall
https://repair.maytag.com/repair/dishwasher.jsp?siteCd=MT_EN_US
It is for a leaking rinse aid reservoir. The rinse aid leaks down onto the wires and causes problems.
[COLOR=Blue]Third time in five years, the control panel has gone out.[/COLOR]
When you say gone out do you mean that it is totally dead?
As other problems can exhibit this symptom re: door switches.
[COLOR=Blue]Any problems on grounding, etc.[/COLOR]
As far as I know no. Perhaps someone else has heard of a problem.
I would check that the hook up is properly grounded?
Also is the unit on a separate line? If it is on a line with an appliance that draws a fair amount of current you may be getting voltage spikes from the other unit.
