I would like to know how to test the control panel to see if it is working. Every once in a while some lights will light up but it will not turn on. It turned on a few times after it quit lighting up but will not turn on now. I need to know what to replace on my dishwasher. Thank You
Replacement parts for MAYTAG MDB8600AWW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/maytag_library/docs/16021814.pdf
http://www.servicematters.com/maytag_library/docs/16026390.pdf
First make sure the units power connection is OK. Have seen a number of units where the wirenuts (if used) were not properly connected and finally caused problems.
Could be a bad door switch but from your description it is more likely a keypad problem. The tech sheet gives the procedure for checking the keypad using a meter.
Also very possible that it is just a bad ribbon cable connection.
Looks like the end of the ribbon cable just has some insulation removed. It can be cleaned using a pencil eraser. Do not use an ink eraser as it is too abrasive. The connector on the board can be cleaned using electronics cleaner or isopropyl alcohol and a tooth brush. Just be sure that all the solvent has evaporated before reconnecting.
Be sure to disconnect the unit from power when doing this.
If the keypad and the door switches check out OK then odds are high that it is the control board.
