Control panel ant nest! How do I put it back together again?
Help! We discovered an ant nest in our control panel in our dishwasher… we took it apart and had ants crawling everywhere and didn’t write down which wires were connected where. They aren’t labeled well, but do have different colors. Can anyone help?
Thanks!
Your Model Number seems to be missing some digits. Probably at the front.
I cannot find a wiring diagram for this unit!!
Check behind the kick plate to see if there is an envelope either taped to the kick or the unit itself.
Thanks for the reply. We found the wiring diagrams and pieced things back together and it seems to be working ok! And without any ants.
thanks!
