[quote=Bob Engelman;285422]Joe,
Today I removed the control board and found a couple hot spots. One of the 4 wires running to the CON2 connector got really hot. The male connector to the hot wire pulled out of the board when I removed the female wiring harness plug. I also removed the board from the plastic holder, and found a lot of black carbon and maybe some solder deposited on the bottom side of the board. Some soot was also deposited by the thermal fuse. The fuse checks good for continuity, so I guess it is still good.
I found the tech sheet which shows 3-7 ohms spec for the wash pump run winding and 6-10 ohms for the aux winding. The tech sheet also shows 16,3 ohms for the drain motor.
What is the best way to check the pumps resistance? Does this require removing the machine and gaining access to the bottom side? Which specs are correct? How do you check run and aux winding resistance? What does the drain motor 16,3 ohm spec mean?
Many thanks for your valuable advice…[/quote]
Bob,
I’m pretty sure you’ll be fine with a new control board(since the pin pulled out )
For access to the pump and drain motor winding tests, No you do not need to remove the machine.
You need to remove the kick plate panel and the lower access panel, that should give you access to the harness connections to the pump and drain motors and check the resistance(s) on the terminals of the component.
(when you place the meter probes on the two terminals on the drain pump motor you should read 16.3 ohms resistance, (+/- 10%).
You may find it easier to check circuits at the control board.
Across the P3 and P10 wires you should read the Drain Pump motor at 4.2 to 7.0 ohms.
Across the P5 and P9 wires you should read the pump motor at 10 ohms.
I’m using the strip circuit diagram,and you’re correct there are two different resistance readings for the drain pump.
I would go with the numbers I gave you.
Good Luck,
