Control board is flashing but washes on hot only
Brand:GE
Model Number:GFWH1400D0WW
Main Symptom:Washes only on Ex Hot
What happens & when: We can Power on the washer. The control board flashes everywhere but no legible codes. All the lights on thecontroboard are lit up. Once you press start it will wash through the entire cycle on extra hot extended spin and heavy soil is this the control bard that needs replacedl control
Error Code (if any):none
Parts or tests already tried:none
Based on this information, it does sound like the main control is an issue. If you unplug the power cord for a minute, then plug it in and press Temp-e Wash-Temp-e Wash within 30 seconds of plugging the cord in, the washer should enter into a service mode. The cycle knob can be rotated clockwise until t02 is shown in the display and start can be pressed. If an error code was identified, it should show at this point. Will it enter into the service mode and if it does, is there an error code in the display after entering the t02 selection? Here is a link to the main control used with this model. WH12X10544 Washer User Interface Control Board | Genuine Ge OEM In Stock
