Compressor is clicking every 2 minutes freezer starting to thaw but cold
Brand: Kenmore
Model Number: 253.6581250A
Main Symptom: Compressor clicks and is hot
What happens & when: compressor clicks every 2 minutes and is hot, ordered refrig compressor start device, but now not sure if that will work since I am seeing thawing in the freezer… will this work?
Error Code (if any): no
Parts or tests already tried: unpluging Refri
That clicking and the fact the compressor is hot indicates the compressor is trying to start/starting, especially if you’ve got any kind of cooling going on. This sounds like you might have a compressor that is going out and tripping the overload.
https://www.appliancepartspros.com/frigidaire-compressor-kit-5304507765-ap6038361.html
