compactor will not stop when it reaches the top
Top limit switch may be out of adjustment or defective. Two clicks must be timed correctly and arm must be bent to right adjustment. Also test switch with multi meter. Also Stop switch at bottom of unit should be tested. It is the switch that pushes with your foot peddle. Other switches on unit should be tested with meter as well. Al
