I am having problems finding any information on running the diagnostics on this unit any help would be appreciated. I have changed out the lid latch assy. to no avail. Thanks for any assistance.
Jim
There should be a tech sheet underneath the top. See if you can find it and use it to do some testing and generate some diagnostics.
Thanks I will pull it off in The morning.
Jim
Got the sheet and ran diagnostics. We keep coming up with F7 and E1. We also fail spin cycle and every led lights up on the control panel and just flashes 71.
Thanks in advance you your help
Jim
Good, the tech sheet should tell you how to interpret the codes and what to do.
