Close washer, making grinding sound in rinse cycle, tub still agitating Replacement Part#?
Brand: Kitchen Aid
Model Number: KAWS850LQ1
Main Symptom: Cloths washer, making grinding sound in rinse cycle, tub still agitating
Replacement Part# ??
With the unit making a grinding noise during the rinse cycle then check to make sure that there are no clogs in the drian or that the drain pump is not causing this issue.
