Clean light
the clean light keeps blinking. I had a repair man about a year ago and he reset the panel. He wrote down the code but i lost it. Do you know the code to reset the panel?
you do a keypad dance i think its hi temp wash air dry hi temp wash air dry hi temp wash air dry then press start then cancel. The reaSON ITS BLINKING IS THE LAST RINSE WATER EITHER DIDN’T HEAT OR TOOK TO LONG IT COULD BE A BAD HEATER OR IT FILLED WITH COLD WATER AND DIDN’T HEAT IT ENOUGH OR(sorry caps) the board is bad hope it works
Did you check behind your lower cover for instructions?
