the dishwaher starts and goes through all cycles fine but when it is finished the clean light comes on and it won’t do anyghing else. I have to unplug the unit and plug it back in and then you can run the dishwasher again.
Hi.
Most likely the problem is bad control module
[PART]154712101[/PART]
Here are the breakdown diagrams and Replacement parts for Frigidaire FDB1050REQ4 DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
