cleaning light blinks. I unplugged it pluged it did not change.with
light blinking no other buttons work:)
The model number you posted is incomplete. Verify and repost it please.
[SIZE=3]Thanks Gene[/SIZE]
[SIZE=3] The model #KUDPO1IL BTO [/SIZE]
[SIZE=3]KITCHENAID DISHWASHER
CLEAN LITE BLINKS UNABLE TO GET IT TO STOP[/SIZE]
[SIZE=3]IT BLINKS SEVEN TIMES PAUSE THEN BLINKS SEVEN MORE
LIKE THAT IS A CODE
THANKS
CARL[/SIZE]
Carl,
Press the following option keys: High Temp Scrub - Energy Saver Dry - High Temp Scrub - Energy Saver Dry to start the diagnostics cycle. Press the Heavy key to advance it to the end.
Run the dishwasher as usual. If the problem returns, then you’ll have to check the heating circuit.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDP01ILBT0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
