Brand:Maytag
Model Number:MVWB865GW0
Main Symptom:DOESN’T RUN ANY CYCLE
Parts or tests already tried: JUST CHANGED THE MAIN BOARD AND IT JUST LOCKS THE DOOR AND RUNS THE SENSE CYCLE THEN ABOUT 4MIN LATER IT SAYS DONE
If you try running the Clean Washer cycle does it do the same thing?
yes i tried it and the machine locks the lid and just sits there. no water and no movement
I have an lg washer model 7500cw I changed the control board and the washer won’t turn on I put in the old one it works did this with another new board same result it is the same exact part number as in the machine I own
I’d check for items stuck between the inner and outer tubs that could be causing drag or binding, that happens sometimes. At that point, if nothing is found between the tubs, it is an issue with the lower harness, the clutch assembly, the stator motor, or the gearcase. There is no way to test which it is going to be without replacing each part in turn, and sometimes you can replace all of them and the issue still happens.
This model has a 10 year warranty on the motor, so your best bet is probably going to be contacting the manufacturer.
Please post this in a separate thread.
How not clear how to start one
Click on the “Ask a Question” button at the upper right side of the page.
how do you run the calibration on this model? or clear codes ?
Here’s the tech sheet, it goes over all that.
techsheet-w10607408-revf (9).pdf (2.5 MB)
