CFE29TSDFSS with water dripping into Ice bucket
Brand: GE
Model Number:CFE29TSDFSS
Main Symptom: water leaking into ice tray/out water dispenser
About 12 years old. French Door fridge with freezer on the bottom with the ice tray and dispenser on the refrigerator door.
I noticed frozen water sliding down the side of my ice bucket. It seems that the ice bucket is being slightly overfilled or just water is dripping down. If left alone for day, the ice bucket gets a bit messy with water frozen on top of the cubes.
I replaced WR57X10102 which is the in door tri valve from Appliance Parts Pro earlier this week and that doesn’t appear to have fixed the issue. Should I try to replace the ice maker assembly next? I don’t think the main inlet valve (WR55X11128) on the back of the fridge is the issue based on my understanding of how the water/ice dispenser valves work.
I just dont want to spend another $100 if this isn’t going to fix the issue. Is it possible that the new WR57X10102 is defective? There also seems to be an ultra slow drip from the water dispenser which could also indicate a valve not being entirely closed. Like 1 drop falls every hour or so. Not sure what else it could be.
I appreciate your help.
This issue would most likely be caused by a faulty icemaker that would need to be replaced.
