Caravell commercial Ice Cream display freezer
Caravell 335-945 model Ice cream Display freezer, lowest setting, still well under 0 degrees
while compressor and fan run constantly. Thinking the thermostat is faulty or compressor run relay.
Your thoughts??
0 degrees Fahrenheit? Do you want it colder than 0? Its not necessary to run it that cold. If it can’t get below 0 F, then it might be a little low on freon. Is the condenser coil clean and is it hot?
Happy with temp. in the box. Disappointed that the unit runs all the time, never shuts off.
Pulled the Temp. control/thermostat, looking for replacement, that is compatible. Thanks in advance, Dale
