Can someone help me with a Bosch soap dispenser
Hello group,
I have this Bosch dishwasher and I suspect there is something wrong with the dispenser but not sure. It’s the upgraded dispenser that pops out so you don’t have to lay the door down flat to fill. I was reading in the manual and it states that if you want to pop the dispenser out to fill you push the blue button. But mine pops out all the time when it opens. I am thinking this is not correct as it angles the dispenser at a 45 degree angle to the top of the machine so the soap isn’t easily washed out. It’s been this way since it was new but I didn’t use the dispenser (dropped the pac in the bottom) But given the manual states to push the blue button on the end of the hinge to release it, I’m thinking it’s broke. I have included a picture (stock photo) of the dispenser I have. Even in this picture the dispenser is open and flat which mine would be popped out. Thanks so much!
Oh and the problem is, the new powder I am using is not dispensing fully.
Cheers,
John
Just in case someone else has this problem… I did. I followed online instructions to remove the dispenser door and little blue control shaft thing, which required taking the dishwasher door panel off. There was caked-on soap on the blue plastic shaft that was inhibiting it from turning …darn eco-friendly soap! I cleaned it all out, both the shaft and the hole that it goes through, then put a thin film of silicon grease on the shaft and gasket… works like a champ now, and no more of that ‘will not rinse off poser soap’ eco-friendly soap in MY dishwasher!
Brian
