Here’s what happened: The machine could not stand the wear put on it by the 8-10 people living in our house and gave way to terrible knocking during the spin cycle. It went ignored until it finally quit spinning all together. During the spin cycle, the drum quit spinning, but it sounded like the belt was trying to turn it regardless.
I had the machine diagnosed by a repair person as needing a new rear drum bearing kit, and belt. He said it was most likely caused by over loading the machine, which is very likely true.
After researching a bit, I could find no way of replacing the bearing alone, but would need to purchase the whole drum assembly, which I doubt is necessary seeing the machine is barely over a year old. I would much rather keep the current drum and replace the bearing separately. Any comments?
Also…seeing that the machine ran for some time while it was damaged, would there be need to worry about changing the shock absorber as well? Or should the new bearing/tub assembly and belt do the trick?
Thanks for any advice…
Jesse
