Can I purchase a drain pump motor by itself? The one for my model is sold only as the drain pump assembly
Brand: Maytag
Model Number: MHWE950WW01
Main Symptom: Not draining completely
What happens & when: Will make it to a certain point the throw the f20 code.
Error Code (if any): F20
Parts or tests already tried: Drain pump rattles when hooked to a cord. Water in filter stinks as if its been there a while but it does drain some. Have thoroughly cleaned and tested all water inlets and dispenser tray.
It is recommended to use only the OEM parts, and for this model, the pump comes complete:
https://www.appliancepartspros.com/whirlpool-washer-drain-pump-280187-ap3953640.html
The F20 error code relates to the incoming water and/or the pressure switch.
The machine has not detected from the pressure switch that water is getting into the machine, or not enough water to trip the switch. It is advisable to check the pressure switch and the pressure hose.
https://www.appliancepartspros.com/repair-help/
Thank you. I am doing that today but my drain pump was def bad so am replacing it while I have it torn apart.
