The circuit board is burnt at the “con2” connector, the connector for the wire harness at that point is melting. I’m assuming I need to replace the circuit board. Is that true? (see also my last question)
The wire that leads away from that spot looks slightly melted but still has structural integrity and the wire is not exposed. The connector is melted but also has structural integrity and has not exposed the connectors. Can I continue to use that wire harness?
That same wire goes to a module labeled “microtemp” so I’m assuming it’s job is to prevent this exact situation from turning into a fire. How do I test that this part is ok?
And finally, what is likely the root cause, I don’t want to replace these parts only to burn them out again immediately.
thanks in advance.
When the team was renamed the Titans, the club introduced a new logo: A circle with three stars, similar to that found on the flag of Tennessee containing a large “T” with a trail of flames similar to a comet. The uniforms consist of white helmets, red trim, and either navy or white jerseys. White pants are normally worn with the navy jerseys, and navy pants are worn with the white jerseys. On both the navy and white jerseys, the outside shoulders and sleeves are light “Titans Blue”. In a game vs. the Washington Redskins in 2006, the Titans wore their navy jerseys with navy pants for the first time.The NFL jersey is a fan favorite with a quality look and feel. Made of breathable, quick-drying mesh, this Tennessee Titans jersey officially licensed jersey is designed with printed player name, number, team wordmarks, logos and sleeve stripes. Like the nfl jersey game,try the NFL jerseys for your support.Since 2000, the Titans have generally worn their dark uniforms at home throughout the preseason and regular season. The Titans have worn white at home in daytime contests for a few occasions in September home games to gain an advantage with the heat. The Titans wore white at home twice in 2000 and 2002. The Titans wore white once at home in 2001 against the Tampa Bay Buccaneers, in 2004 and 2007 against the Indianapolis Colts, and once in 2009 against the Houston Texans.Whatever they win in the game or lost.Their amazing fans always are wearing the Tennessee Titans nfl jerseysto support them anytime and place.Best wishes for the all.
