I need to replace my bottom washer arm its clogged. I dont see any screws to remove. how does it come off? ![]()
Replacement parts for General Electric PDW7800J15BB Dishwasher | AppliancePartsPros.com
Here is a manual not for your iunit but I think the pump is the same so it may be useful.
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
You may have to join the site to download the manual but it is a good site for service info.
Lift spray arm assembly and turn it counterclockwise.
I holes are plugged with food particles often it is easiest to run water into the main opening and then pull the food particles out with a pair of tweezers.
