Bottom of Dishwasher door leaks where it folds down
I really don’t know the age of this dishwasher it came with the house when my wife bought it. It was leaking in the lower right corner, dripping out I washed the inside back and now it’s leaking through the whole bottom part, it looks like maybe a gasket or something between the door and the access panel below. But i am not locating a gasket for parts. Does any one know what it could be?
Any help would be appreciated, I am horrible at anything home improvement. I have included a picture of the bottom of the machine the crack is where it is leaking at. Wanted to see if it can be fixed cheaply before buying a new dishwasher.
Washing machine problem leaks in crack 001.jpg (34.4 KB)
Sometimes when they leak there it’s because the water is spraying directly on it instead of up to the dishes.Look closely for a crack in the spray arms and if you can cover the opening you can run it with the door open to see if any water is spraying directly on it.
there is a vent 0n the inside of the door, this vent may be plugged , remove this vent and see if there is any thing that would plug the vent holes .
I recently had the same problem and cleaning the vent solved the leak problem it looked like a grease substance .
