Bosch SHX7ER55UC/50 filling after cycle completes
Brand: Bosch
Model Number: SHX7ER55UC/50
Main Symptom: Water fills after cycles ends
What happens & when: When the dry cycle ends there is no water in the tub. All is good. If I do not run the machine within a couple of days, the tub will fill with water. Water is clean. I can run a reset to drain the water, but it does come back if left long enough (a few days)
Error Code (if any): None
Parts or tests already tried: I turned off main water supply. Did result in less water, but tub still slightly filling with clean water.
Hi sbelin,
If the washer is filling with water on its own, it sounds like you may have a bad water inlet valve. A faulty inlet valve can get stuck open, allowing water to continue flowing into the machine even when it shouldn’t.
I’d really suspect that the dishwasher’s water inlet valve ( Bosch 10023852 Dishwasher Water Inlet Valve | Genuine OEM Part ) is leaking by. The fact that you’re still getting water in the tub after shutting off the household supply valve also makes me wonder if that supply valve isn’t sealing completely.
A simple way to test both at the same time is:
  1. Turn off both the water supply valves.
  2. Disconnect the fill hoses from the dishwasher.
  3. Watch the supply hose for a few minutes. If you see continuous drips, that household shutoff valve is leaking and should be repaired or replaced.
  4. While the hoses are disconnected, leave the dishwasher sitting for a while. If you still observe water collecting in the bottom let me know
This test will help you determine whether the problem is the home’s plumbing, the washer’s inlet valve, or both. Let us know what you find, and we can help you narrow it down further.
I am fairly certain that its the Bosch’s inlet valve as well. However, looking at the schematics for this machine, Bosch is telling me that the necessary part is this: Aquastop Hose 00674387. What am I missing? Here is Bosch’s parts site: Replacement Parts - SHX7ER55UC/50 | BOSCH US
Thanks, Steve
Yeah It has the valve built into the hose, didn’t realize it had the aqua stop sysem
Just so I am clear, I need to purchase which part number? Thank you, Steve
00674387is the part number
