Bosch SHU53E06UC/14 won't drain, looking for instructions on how to remove pump
My Bosch SHU53E06UC/14 will not drain. I am trying to get the pump\impeller out and could use some advice on the best way to do this. There does seem to be a lot of sediment (perhaps detergent) in the well and when the cleaning cycle is over there is water in the bottom up to the level of the door.
Update- I took apart and cleaned the impeller and bowl assembly. I took apart pretty much everything else I could. I still have water in the unit when the cycle is over. Can anyone offer input as to how the dishwasher knows it is empty, like a sensor\switch?
