Check the drain hose next, make sure the hose is clear and does not have an obstruction inside, if the hose is clear and pump is getting voltage replace the pump.
we are having the same problem we want to know what screw driver and size will take the door apart..help please. then we have to replace the soaked insulation but that is not the cause, obviously…
