Problem
Dishwasher runs forever, water spits out of washing arm, that is all. It appears that the unit is not filling with water. I suspect fill valve is bad. However after reading forums about long wash cycles I suspect control module. or both.
I ran the self test, the lights flash the display reads the number zero but it never finishes and the lights continue to flash. Is this normal or does the module sound bad?
Thanks!!
[QUOTE=ceo5514;478936]Problem
Thanks!![/QUOTE]
I have a SHE46C model…how do you run a self test?
