Bosch oven HBL54 or HBL56 broiler starts when setting is on bake
Brand: Bosch
Model Number: HBL 54 or HBL 56
Main Symptom: oven heats to broil when setting is on bake
What happens & when: it just started but is doing it consistently
Error Code (if any): No error code
Parts or tests already tried: shutting power off and turning it back on
MBCC,
The broil will normally come on to help with preheating and for even cooking but should not stay on. If it is happening and the broil is staying on continuously then the control board would be the most likely cause for this issue.
The broiler does stay on. I replaced the display module in 2023 - is that a different part than the control board? I just bought a new sensor to test whether a faulty sensor was the issue. Thank you for your feedback!
If you could get me a full model number I can help you with the part that you would need.
