My drain motor runs continuously but no water comes in to the tub. Don’t know if it is the float assembly or it needs a new water inlet valve. How do I tell?
Pull the dishwasher out of the cabinet. Remove the left side panel. Check the water fill assembly as instructed in the Manual (pages 91-93). Post the results.
Here are the breakdown diagrams and Replacement parts for Bosch SHU3032 UC/12 (FD 8003-) | AppliancePartsPros.com
[quote=Gene;642232]Pull the dishwasher out of the cabinet. Remove the left side panel. Check the water fill assembly as instructed in the Manual (pages 91-93). Post the results.
Gene.[/quote]
Thanks, I did the above but decided that since the dishwasher was over 10 years old to get a new one as much as that goes against my grain.
