As I was loading my dishwasher this eve, my 80 lb dog stepped on the door while in the down position. It now extends slightly past 90 degrees and has a slight “click” when putting in up position.
Do I need to change the hinges? Is there a stop I can adjust?
The hinges will indeed need to be replaced. May I please have the rest of your model number so I am able to provide you with accurate, model specific information?
From the side of the door…
SHU5305UC/UC12
I’m pretty handy and mechanical…is there a manual to see it?
Thanks for your help.
The hinges you need are below!
Bosch 00263119 Lever Hinge, Right Side - AppliancePartsPros.com
Bosch 00263115 Lever Hinge, Left Side - AppliancePartsPros.com
To access them, you will need to remove the screws from around the inner door panel and remove the outer door cover. Then, with the appliance pulled out from the cabinet, you will have full access to them for replacement.
