My Bosch diswasher is leaving particles and grit everywhere…even the door. It runs it’s cycle (although noisery than usual). The washer goes through it’s cycle, and the sand-like grit and particles are baked on. Any suggestions? I’ve checked the filters and cleaned them to the best of my ability.
Is there enough water?
The model number you posted is incomplete.
The model number is SHX46A0Suc/14
fd8407 00150
How does one check if it is getting enough water? I put it on regular or heavy cycle. I’ve checked the filter and jiggled the hose going under the sink.
Thanks!
The water should be about 1 1/2" above the floor.
