Bosch dishwasher
Dishwasher will not drain. do not hear pump turn on when you press cancel/drain buttons. Filters and hose are clear.
Remove the toe panel and check for 120 VAC to the drain pump while the control calls for drain. Post the results.
The model number you posted does not come up. Verify and repost it.
