Bosch dishwasher wil not wash help!
I have a Bosch dishwasher shy66c06us. The washer comes on and I have noticed the following:
  1. does not wash the items
  2. There is water in the botton of the machine.
  3. when I open it during mid-cycle water is only coming slowly out of the botton sprayer. I try to use only the top tray, but no water make it to the top.
  4. The soap tray is open with soap not used.
Remove all filters and screens on the bottom of the dishwasher as described in the Owner manual and make sure they are clean.
I check the bottom of the machine and it is clean(I did what you recommended).
So I try the dishwasher again. This is what happen
  1. the first time the machine let the water out, but nothing is clean.
  2. I try it one more time, this time, it did not let the water out, and the items are still not washed, also the soap in not used(the soap dispensor is open).
rpatters
Sounds like there are problems with the circulation and the drain pumps. The dishwasher has to be removed from the cabinet for more exact diagnosis an/or repair.
I have remove the machine, what am I looking for?
How do you get the white bottom piece off of the housing of the dishwasher???
You can find the instructions in the attached files.
How to remove the base from the tank.pdf (190.1 KB)
How to remove the ciculation pump.pdf (213.7 KB)
I have order the parts, I will keep you all inform of my progess.
[quote=rpatters;46080]I have order the parts, I will keep you all inform of my progess.
Thanks[/quote]
You never let us know… Did it work?
