Bosch DIshwasher (water in bottom pan)
I’ve been having a problem with my dishwasher above and am trying to determine which of these 2 parts (if either) would most likely be the culprit. The Water Inlet System or the Water Level Switch Assemby?
My dishwasher is getting water in the bottom pan which trips the red safety lever causing it to go into the drain mode. I cannot see a visible crack or leak.
I did notice after taking off the metal cover that there were water stains that lined up with the overflow hole in the Water Inlet System.
I’ve referred to posts from Dennis 3/2008 and Lgraf 4/2008 but all I can get from it is my machine could be “out of level”. I guess after 5 years anything is possible.
Were you able to solve this problem? I have an overflow issue through the vent hole on my water inlet system.
