Our Bosch dishwasher SHX46A05UC/14 is not draining. I have power, when I press the drain button combination the drain pump appears to be working and when I quickly open the door I can see the blue impeller spinning after I had cleanedthe filters and area around the impeller. What else should I check?
Thanks!
