Washer cleans well, but the timer will go to 1-min and just sit there
washing forever. Water doesnt seem very warm when I open the door.
It does it in every wash mode, even quick wash. It may have nothing to do
with heating the water as I dont thing quick wash heats the water.
I am sure that this has been seen before, just cant find it or the model.
I tried looking up the model on the door SHE56C05UC/36 and
any combination and cant seem to find anything close.
I can use the 2 buttons and reset it so it will drain, then use the
rinse and hold to flush it out
i don’t know if this will help, but my old Bosch dishwasher did the same thing. Problem was a faulty circuit board (soldering joints). Bosch knew of the problem (defect). Replaced the circuit board. Problem went away. Then after awhile, did the same thing. They replaced the circuit board again - never had another problem after that.
Had the new main module replaced and all is well. When the guy
pulled the old one out, I opened the plastic case it was in. There
was a burnt spot on the board just like in other posts.
My washer has a 5-yr warranty for circuit boards and such, so it was just\labor of $100. That was just a few $$ more than just the board and shipping.
