Bosch Dishwasher outer door re assembly
I replaced the control module on my Bosch SHU4306 dishwasher and I am trying to put the door back together. There are 2 parts, the door and the top piece which holds the control module.
Which one should I screw in 1st. The door or the top piece. It seems like I need about 4 hands to accomplish this. Any help is appreciated. Thanks
John
John,
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for Bosch SHU4306 UC/11 (FD 8001-8003) | AppliancePartsPros.com
How to replace control module.pdf (54.6 KB)
[quote=Gene;310272]John,
Gene.[/quote]
Thanks Gene, I got it all back together and thanks to everyone else on the forum explaining the control module replacement.
It was very easy to replace the module, but a little tricky getting the door back on by myself, it would of been easier with two people.
used the instructions to locate and repair bad solder connection on control board. Worked like a champ.
I see this has been an issue for a long time. Recall??? board appears overheated by current not cold solder.Bad design??
How many poor bastards don’t run across this fix and spend ridiculous $ on the repair. Bosch is supposed to be 1 of the best brands.
JA
I’m in the process of fixing the red wire soldering on the Control Module, and have seen a reference to a Test Program. Can somebody please shed a little light as to how to invoke this? Thanks in advance Pridbor
