Brand:Bosch
Model Number:SHEM 63W55N/20
Main Symptom:water coming but sprayer arms not spinning
What happens & when:blades not spinning during wash cycle
Error Code (if any):none
Parts or tests already tried: removed and cleaned upper and lower arms
Are you getting good water spray from/through the arms?
There is water coming in from the recirculating pump but not enough to make the sprayer arms turn. I took the entire dishwasher apart to order a new pump but I’m not sure that is the problem because I saw no obstructions in the original pump. Today I noticed that there is water switch motor that slides a disc back and forth to control water flow. I’m wondering if that assembly is working correctly. I’d like any feedback.
That’s actually where I was headed with it. You can get the individual diverter motor but I’d recommend replacing the diverter valve assembly AP5691407.
https://www.appliancepartspros.com/bosch-altern-water-distributor-751950-ap5691407.html
OK, I’ve ordered the diverter valve assembly. If the old circulating pump is working and the new circulating pump is unopened can I do a return? Thank you
You should be able to do that, our return policy is linked below:
https://www.appliancepartspros.com/customerservice/returns.aspx
