washer is covered with condensation . the back wall is covered , bottom of the counter is swollen. No water is on the floor . no leak in the drain line. There also is no pressure on the door when closing tight.
What is the complete model number of the dishwasher?
the model number for dishwasher with condensatio all over it is # SHE 44CO5UC/43
Did you replace the detergent disperser recently?
No soap dispensor change. She had the electronic board in the door replaced. Tha the only service on machine.
Pull the dishwasher out of the cabinet. Remove the right side panel and check the condensation tube which is attached to side of the dishwasher and coming down under the tub.
Is that the same as the drain line? Or is this a different line. I will check tomorrow. Thanks for info.
No, it has nothing to do with drain.
