I have a Bosch SHX46B02UC/21 that runs constantly and never finishes. Searching the forums, this seems to be the same problem many have experienced with the SHU models, but I can’t seem to find out any info on the SHX. Does this model also suffer from the “cold solder point” on the board in the control module, or is it more likely to be the module itself or the heater assembly? Any instructions on how to run and interpret the diagnostics on this model? And, last, do you know the part numbers for the control module and heater assembly if I need to order replacements?
Thanks for your help!
