Bosch circulation pump
Bosch needs new circulation pump(works fine just very noisy when running) Told need pump AP2826384 .When installing ,will I need to have other parts such as gaskets or anything on hand.I don’t want to get it out then find I need something else.Your help is greatly appreciatted.
Thank you
Phil
There’s a one-time use clamp that is used on the seal that goes between the pump housing and the heater which you should also have on hand. The Bosch number is 172272.
