Dryer turns, but suddenly no heat. Perhaps it’s the dryer thermal fuse? Literature says fuse “is located on the blower wheel cover.” Where is that located?
Here are the parts
Replacement parts for KENMORE 11066662501 | AppliancePartsPros.com
If you go to the Sears parts site they have part breakdowns.
[COLOR=“Blue”]
Dryer turns, but suddenly no heat. Perhaps it’s the dryer thermal fuse? Literature says fuse “is located on the blower wheel cover.” Where is that located?[/COLOR]
This is inside the unit by the motor.
This will not be your problem as this fuse kills power to the motor.
It could be the thermal cut-off (fuse) mounted on/close to the heating coil.
If this is blown there are other things that have to be checked before replacing it.
Also could be the heating coil is burned out.
Remove the rear cover to see the above.
The first thing to check is power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
The heating coil requires the full 240 volts.
Here is a link with basic dryer repair help.
http://www.applianceaid.com/dryers.html
