hi .how to change a coupling drive thanks.
There are no couplings in dishwashers. The model number you posted is most likely for a refrigerator. So, what is your question about?
ksbs5wh3 its the mod #, the serial # is wj4364177 its coupling drive part is striped and before order it i want to make sure i will be able to take off the bad part pleasecan you tellme how to take it off ,thanks very much.
