when I try to start my kenmore dishwasher there is a blinking green light, which is the ‘dishes are clean’ cycle. This green light is always blinking.
press the heated dry button then normal wash and repeat same quickly all lights will come on then hit cancel that should get the flashing clean light off and machine should be able to be used again. It worked for me thanks to another helpful person. Good Luck!!
worked great, got it to work the first time, sears people wouldnt help at all just hung up on us[quote=lorraine frish;549847]press the heated dry button then normal wash and repeat same quickly all lights will come on then hit cancel that should get the flashing clean light off and machine should be able to be used again. It worked for me thanks to another helpful person. Good Luck!![/quote]
worked for me too – i used “heated dry” and “steam santize” buttons but it worked the same. Thanks..
