Brand: Samsung
Model Number: WW22K6800A
Main Symptom: smoke smell coming from within the tub
What happens & when: After a spin cycle
I’ve only started looking into this issue this evening. My wife and my one daughter said they smelled a burning rubber smell and smoke came from the tub when they opened the door. My daughter also said she heard banging from it when she ran a load earlier in the day.
I just ran a rinse and spin cycle and smelt and saw the smoke from the drum/tub area when I opened the door, but didn’t hear any of the banging my daughter had described during the spin portion of the cycle. While the drum was spinning it did not appear to be spinning in an out of balance way, but there was still the smoke. There was also nothing in the cycle other than the water, so maybe if I added some towels and tested again it would present the banging during the high speed spin.
I initially suspected something had become lodged between the drum and tub, but my daughter’s observation of a lot of banging/noise leads me to believe it may be failed bearings and/or seal on the back drive shaft that’s allowing it to spin off-centre and rub the rubber front gasket or the plastic tub in some area. There only appears to be .125”-.25” free play between the front edge of the drum and the plastic tub. Is that too much or is it within spec and I should assume the bearings are fine?
I feel comfortable disassembling this but would like to know what parts I should be ordering to minimize downtime. We’re a house of myself and 6 other of my people who seem to do 3 loads each everyday with no more than 4 items per load. Needless to say I’m getting some heat here!
SOS!
